Hi, if you have the spider fuel system, the pressure is too low, it should be 60--66 psi. Have you changed the fuel filter recently? If you change the filter, make sure there is no pressure on the system.
Proper fuel pressure is critical on the spider system. Sometimes the fuel poppets need cleaning.
SPONSORED LINKS
Sunday, May 2nd, 2010 AT 12:23 PM
