MY JIMMY WONT START WITHOUT USING STARTING FLUID. THERE ARE NO CODES CHANGED PLUGS ROTOR, CAP HAD COIL AND INGNITION MODULE CHECKED ALL OK. FUEL PRESSURE WITHOUT STARTING IS AT ABOUT 44 PSI. ONCE I START THE TRUCK WITH STARTING FLUID SPRAYED INTO THE INTAKE IT SEEMS TO RUN FINE. IT WILL RESTART AFTER 5-10 MINUTES OF SITTING BUT NOT AFTER AN HOUR. WHAT CAN I DO
SPONSORED LINKS
Saturday, October 18th, 2008 AT 2:00 PM
