1998 GMC Jimmy oil pressure
1998 GMC JIMMY
JAYMELUVSCHARLES
Engine Performance problem
1998 GMC Jimmy 6 cyl Four Wheel Drive Automatic
oil pan full has no oil pressure. Plesae give most common reasons and if it is the iol pump, does the motor need to be pulled?
May 3, 2009 at 1:49 PM
  • 110,244 POSTS
When the engine runs, does it knock and tap? If not, try replacing the oil sending unit. If it does knock and tap, chances are the oil pump is bad or the screen on it is plugged.
Let me know what you find.
May 20, 2009 at 6:36 AM
