1997 GMC Jimmy
STACYKID
  • 1997 GMC JIMMY
1997 GMC Jimmy 4 cyl Four Wheel Drive
How to remove window motor? I have drilled out the 4 rivets but I don't know how to disengage the regulator from the window glass sash & lift it from the door. Please help!
Thanks, Joe
Sunday, June 27th, 2010 AT 4:37 PM
HMAC300
  • 48,601 POSTS
There will be either a bolt for each position or they could just slide in. If the window is up you'll have to let it down where you can slide your hand there and see what you have.
Sunday, June 27th, 2010 AT 8:22 PM
