1996 GMC Jimmy wont start
BAKERTYS
  • 1996 GMC JIMMY
  • 6 CYL
  • 146,000 MILES
Vehicle was running fine when I parked it.
sat for 5 days. Now turns over but wont start. Plenty of fuel, fuel pump working, tried priming, nothing worked. Acts like not getting a spark?
Monday, January 4th, 2010 AT 6:39 PM
Do below to determine whether it's a fuel or spark problem:
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Tuesday, January 5th, 2010 AT 1:36 AM
