I crank the engine over, and it has power and is turning over but will not catch to start. What should I do?
Sunday, March 9th, 2008 AT 11:54 AM
PEAR69
MECHANIC
Check to see if you are getting spark.
SPONSORED LINKS
Sunday, March 9th, 2008 AT 12:08 PM
HNICHOLS1
MEMBER
I had a neighbor come over to help and he says that I am getting a spark. He checked the plugs to make sure they were all pushed in, and they were. Everything looks like it's connected, there are no leaks or anything. He said it might be the fuel pump. Does that sound about right?
Sunday, March 9th, 2008 AT 1:25 PM
MECHANIC
Sounds okay for me-check the fuel pressure and comeback with the readings so we can continue to assist
Do you hear the fuel pump come On for 2secs?
Sunday, March 9th, 2008 AT 4:10 PM
HNICHOLS1
MEMBER
I honestly have no clue. I noticed just now when I tried to start it that the oil pressure gauge has no reading whatsoever.
I don't even know how to check the fuel pressure. Sorry, I'm a girl that doesn't know as much about cars as I thought I did. :(
Sunday, March 9th, 2008 AT 5:29 PM
MECHANIC
Stop driving it -get the oil pressure check and comeback with some results
SPONSORED LINKS
Monday, March 10th, 2008 AT 5:55 AM
HNICHOLS1
MEMBER
I'm not driving it, I can't even start it. I don't know how to check the pressure for the oil or the fuel.
Monday, March 10th, 2008 AT 8:08 AM
MECHANIC
1st get the fuel pressure check-find someone that knows how to do it this is where we start-we need to rule out the fuel system before we can continue.
Monday, March 10th, 2008 AT 4:21 PM
HNICHOLS1
MEMBER
Thank you for your help, but I couldn't get anyone here in person to help me, so I ended up having it towed in to a shop by me. It was the fuel pump, and is now fixed.
