1996 GMC Jimmy GMC Jimmy Window
HAZELFROG
1996 GMC Jimmy
Driver's window is stuck in the down position. This has happened a couple times before and always seems to work itself out or reset if I unplug and reattach the battery cables (wierd!). Not the case this time.
Not sure if my problem is in the switch or the motor. Any ideas?
Oct 4, 2008 at 11:24 AM
SWILLIAMS
  • 597 POSTS
Check the cable connector for the door switch. The switch assembly just pops out of the door. If you bypass the switch and the window works then clean the switch and test it.
Oct 13, 2008 at 1:12 PM
