I've had a problem starting my Jimmy since last winter.
One morning, the engine would crank but have trouble starting. I could use to crank it enough times to get it to finally start, but as time went on, the amount of cranks increased and my battery couldn't sustain it.
I can hear the fuel pump click on. When I test the pressure, it is at 59 psi. For Central Sequential Electronic Fuel Injection system, that's perfect.
When I replaced the fuel filter to verify that it wasn't an issue, it started up on the second crank. Weird.
If I start it up by spraying fuel down the air intake plenum, it will run for however long I like.
If I turn it off, I can usually get one or two more start-ups again without any fuss, but more then a few tries, it just wont turn on anymore, cranks until the battery dies.
Additional Info:
I've had two instances of my acceleration cutting out. First time was on the interstate passing. I could hit the gas and I would get no response. After about 15 seconds or so, response from the pedal would return and it would be fine.
Second time was going about 20 miles an hour, hit the gas a bit and it lost power, same situation as before.
There's no slipping when I apply acceleration when it idles.
No codes coming up with ODB II.
I've replaced:
02 sensor
temperature sensor
catalytic converter last year
fuel filter twice in 5 months (Its fine)
cam shaft sensor
cap and rotor
all spark plugs. (It gets spark, white)
SPONSORED LINKS
Sunday, November 2nd, 2008 AT 4:31 PM
