1996 GMC Jimmy
EXCLUSIVECARAUDIO
  • 1996 GMC JIMMY
1996 GMC Jimmy
the car won't start whats wrong I changed everything and if there is a fuel cut switch where would it be located?
Saturday, March 6th, 2010 AT 12:32 AM
You don't have a fuel cut off switch try doing below to determine if its fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Saturday, March 6th, 2010 AT 3:55 AM
