1987 GMC Jimmy Rear end
1987 GMC JIMMY
187,000 MILES • V8 • 4WD • AUTOMATIC
TITANFAN0001
I have a 87 gmc jimmy v1500. the drive gear that atatches to the drive shaft broke loose. now i need to put a whole new rear end in. i found one out of a suburban that will fit. i have never done this before and would like some advice on how to replace the rear end, axle and all. is it just as simple as disconnecting the brakes and removing the bolts from the springs and shocks or is there more to it than that?
Mar 6, 2009 at 3:38 PM
HELPING YOU
  • 100 POSTS
That's about it-I'd recommend you verify compatibility-and with 4x4 the ratio...same "axle code"?
Mar 6, 2009 at 3:56 PM
MPBALDA
make sure the gear ratio in the replacement rear end matches the gear ratio in the front end
Mar 12, 2009 at 8:48 AM
