2002 GMC Envoy Hard Steering
HEATHERLAMB
We have a 2002 GMC Envoy 4wd 50,000 miles. We just noticed the steering wheel is hard to turn when you are at a stop or just starting to drive. What is this? We are in Belgium now on a military assignment, so averages of how big of a deal this is would be great.
Thanks,
Kyle
Aug 29, 2006 at 4:33 AM
BURRBRIAN
  • 158 POSTS
I would check the fluid level and next look at the belt and see if maybe it's slipping any. Low fluid level would cause this, also. Those are first things to check. Worst case- you could have your power steering pump or gearbox going out on you. But check the little things first. Good luck :D
Sep 1, 2006 at 10:59 AM
Suggested Repair
Check the power steering fluid level and inspect the belt for slipping. Low fluid can cause hard steering at a stop. If those checks are fine, the power steering pump or gearbox may be failing.
Conversation Summary
The owner of a 2002 GMC Envoy 4WD with 50,000 miles reports the steering wheel is hard to turn when stopped or just starting to drive, and asks how serious it is while overseas. The expert recommends checking fluid level and belt slip first, noting low fluid can cause this, and that a failing power steering pump or gearbox is a possible worst case.
