1998 GMC Envoy Key Stuck in Ignition
GARY P.
1998 GMC Envoy, 70,000 miles.
Key gets stuck in ignition switch.
The key will turn to the accessory position, and the engine will shut down, but the key often won't make it to the last turn that shuts off the current completely and allows it to be removed. It usually comes out after I try again after about 15 minutes, but not always. The switch has been replaced, but it hasn't made a difference. Can someone help ?
Aug 15, 2006 at 3:04 PM
MIKEYBDMAN
  • 623 POSTS
[quote:301413a124="Gary P."]1998 GMC Envoy, 70,000 miles.
The key will turn to the accessory position, and the engine will shut down, but the key often won't make it to the last turn that shuts off the current completely and allows it to be removed. It usually comes out after I try again after about 15 minutes, but not always. The switch has been replaced, but it hasn't made a difference. Can someone help ?[/quote:301413a124]
Your park lock solenoid is not engaging. There should be a small hole on the bottom of the coulm that you can remove the cover, and insert a small screw driver to push the manual release on the park lock solenoid. This will allow you to remove the key.
This solenoid may be bad, however I suspect the Park switch on the Automatic trans controller is probably the problem. It is part of the BTSI system that tells the solenoid we are in park, and it is okay to remove the key.
Depending on whether you have a column shifter, flor shifter 2 wheel drive or 4 will depend on what sends the signal for the park position.
Aug 16, 2006 at 9:58 AM
Suggested Repair
Use the manual release under the steering column to free the key. The park lock solenoid may be faulty, but the more likely cause is the transmission park switch in the BTSI system not signaling that the vehicle is in park. Confirm whether the Envoy has a column or floor shifter and 2WD or 4WD, since that determines which switch sends the park signal.
Conversation Summary
The owner of a 1998 GMC Envoy reports that the key turns to accessory and the engine shuts off, but often will not turn fully off so it can be removed. Waiting sometimes frees it. Replacing the ignition switch did not help. The expert says the park lock solenoid is not engaging and describes a manual release under the column. The solenoid may be bad, but the park switch that tells the BTSI system the transmission is in park is the suspected cause, depending on shifter type and drive configuration.
