2006 GMC Canyon Won't start sometimes
48,000 MILES • 6 CYL • 4WD • AUTOMATIC
SDUNN2110
Just recently the truck has started to not start. I the engine engages but it will not fire. Took it to a shop. The fuel pump, starter, and battery were fine. Now I am starting to think it could be an iginition problem. What do you think and how can I get this checked? Although the engine does try to start it just won't fire.
Problem is to get it to the shop it has to run and if it's running everything checks out just fine. It's a mystery.
Sep 29, 2010 at 10:26 AM
HMAC300
  • 48,601 POSTS
check your crank sensor for ohms. that may be giving you a problem with ohms to high. also as it's an intermitent problem have him run freeze dataon it and it may show up what the roblem is.
Nov 7, 2010 at 1:04 AM
