2005 GMC Canyon
NICOLEB
2005 GMC Canyon
how do you get the rotor off?
Nov 24, 2008 at 7:11 AM
BRIAN 1
  • 1,030 POSTS
is this a 2wd or 4wd vehicle.(it makes a difference).these rotors are no fun to take off!you have to remove the caliper,if its 2wd the rotor unbolts from behind.there is 4 bolts to take off.(I think there 15mm)after unbloting it you will have to pound the rotor off with a hammer,if its 4wd you have to remove the center axle nut.after the rotor is off unbolt the wheel bearing from the rotor.take extra care when pounding the rotor off,you could damage the abs sensor and hub.I know this sounds easy to remove but there not.
Nov 25, 2008 at 2:15 AM
BRIAN-RUTHERFORD
[quote:255e0e915d="brian 1"]is this a 2wd or 4wd vehicle.(it makes a difference).these rotors are no fun to take off!you have to remove the caliper,if its 2wd the rotor unbolts from behind.there is 4 bolts to take off.(I think there 15mm)after unbloting it you will have to pound the rotor off with a hammer,if its 4wd you have to remove the center axle nut.after the rotor is off unbolt the wheel bearing from the rotor.take extra care when pounding the rotor off,you could damage the abs sensor and hub.I know this sounds easy to remove but there not.[/quote:255e0e915d]
dont pound on the rotor it has 6 bolts going into it from the front of the hub. when you take the tire off you can see them. in between the lugs.
Feb 4, 2009 at 7:24 PM
