Headlight issue
MCUBEDNTX
My 1996 Z71 headlights recently started acting crazy, sometimes they would come on, other times they would come on when I tilted the steering wheel back, and now they have stopped all together. Acts like a short, but someone told me it may be the master fuse. Would the master fuse act like this? I was also advised it could be the connections to the multi-function switch inside the steering column. Does anyone have a schematic of the steering column or this multi-funtion switch, or another suggestion.
Nov 1, 2007 at 2:25 PM
PASTORSCOTT
I also have a 96 GMC 1500 that was acting up. the truck woould stall when I turned on the lights or not start unless the parking lights were turned on. It ended up being a problem with the ECM connection inside the dash. Replaced that conntection and havent had a problem since.
Nov 10, 2007 at 4:35 AM
