Electrical problem
1989 GMC C1500 V8 Two Wheel Drive Automatic
When I turn on my lights the the right headlights are dim and the right blinker doesn't work ( on the dash it lights up a light green). When I turn my park lights on and my headlight off the blinker works, but is much faster than the left blinker. When I turn the lights on bright the right side is dim, but on the left side the high beam is bright and the low beam is dim.
the amp meter in the dash does not move when the lights are on, but when the left blinker is on ( the one that seems the right speed) the gague mover with the flash. When I turn on the right blinker ( the one that movers faster) there appears to be more of a draw on the system. The battery Has not run down are seemed sluggish in anyway.
Feb 1, 2010 at 3:42 PM
