1989 GMC Sierra Fuel Economy
JDMILLERWKW
i have an 89 sierra 1500-350 engine- what can i do to get the best possible fuel mileage out of my truck-
Apr 6, 2007 at 5:39 AM
BURRBRIAN
  • 158 POSTS
Well, I would see to the basics such as making sure your timing and idle are set correctly and you are firing on all eight cylinders- fuel pressure and mixture are correct, basically the whole tune-up routine. Then to get the most out of your fuel drive it like old grandpa and grandma out for a sunday drive- keep your foot out of it. Don't know if you are carberated or fuel injected but make sure your mixture is not set rich.Just make sure you are running as efficently as possible drive it easy.No fun but will strech your fuel farther. Good luck.
Apr 7, 2007 at 4:14 AM
MDEWELL
Here's what I would do to verify that I'm getting the best fuel mileage out of a carbed engine.
1. Check for worn/old spark plugs, air filter and fuel filter. Replace as needed. Make sure the plugs are gapped according to your manufacturer specs.
2. Timing Checked according to your manufacturer specs.
Simple steps. :-)
Apr 7, 2007 at 4:38 AM
Suggested Repair
Do a full tune-up: set timing and idle to spec, confirm all eight cylinders are firing, and verify fuel pressure and mixture are not rich. Replace worn spark plugs (gapped to spec), air filter, and fuel filter as needed, then drive gently.
Conversation Summary
The owner of a 1989 GMC Sierra 1500 with a 350 engine asked how to get the best fuel mileage. An expert recommended a complete tune-up—correct timing and idle, firing on all eight cylinders, proper fuel pressure and mixture that is not rich—and easy driving. Another reply suggested checking plugs, air and fuel filters, and timing on a carbureted engine.
