2001 GMC Sierra P0410 Air Pump Fix
GEEWORM
I have a 2001 5.3L Z71 sierra with 70,000 miles. I recently took it for a smog inspection and it failed throwing the code P0410. I checked the fuse, it's fine, at start up the air pump does engage then stops after about 15 seconds. could it be the EGR valve? how can i go about trouble shooting the problem?
Nov 17, 2007 at 10:58 AM
BMRFIXIT
  • 19,053 POSTS
[quote:4611c501dc="geeworm"]I have a 2001 5.3L Z71 sierra with 70,000 miles. I recently took it for a smog inspection and it failed throwing the code P0410. I checked the fuse, it's fine, at start up the air pump does engage then stops after about 15 seconds. could it be the EGR valve? how can i go about trouble shooting the problem?[/quote:4611c501dc]
u need an electric pollution air pump
make sure u change the one way valve and hose if not the old one let water in
causing the failure
Nov 17, 2007 at 2:58 PM
GEEWORM
do you know any place they can be purchased. i checked the local auto parts stores and they don't seem to carry it. do i have to go specifically to the dealer to get the pump?
Nov 18, 2007 at 4:34 AM
BMRFIXIT
  • 19,053 POSTS
[quote:43763715a7="geeworm"]do you know any place they can be purchased. i checked the local auto parts stores and they don't seem to carry it. do i have to go specifically to the dealer to get the pump?[/quote:43763715a7]
NOT sure if aval. on line
last i get one it was from dealer
good luck
Nov 18, 2007 at 7:04 AM
Suggested Repair
Replace the electric secondary air injection pump, and also replace the one-way valve and hose so water cannot enter and cause another failure. The pump was last obtained from the dealer; online availability was uncertain.
Conversation Summary
A 2001 GMC Sierra 5.3L failed a smog inspection with code P0410. The fuse was good and the air pump ran about 15 seconds at startup. The expert said an electric pollution air pump is needed and advised replacing the one-way valve and hose to prevent water intrusion. The last pump was bought from a dealer, and online availability was unknown.
