Thanks
1995 Chevrolet K1500 A/C Dash No Air
Thanks
All doors are driven by a small motor on the side of each pivot. It is a small black flat component with a connector. It can be removed with 2 or 3, 7mm screws. I suspect one is binding or the flap is binding, They are about $40.00 each. If it was me, I would change one from another area as they are all the same. This will isolate if it is the flap/door or the motor. Good luck
Suggested Repair
Recheck the vacuum canister hoses and connections. If vacuum is sound, suspect a binding mode door or its actuator motor, which only fails in the dash position with A/C on. Swap an identical actuator from another door to isolate a bad motor from a binding flap, then replace the faulty actuator if needed.
Conversation Summary
On a 1995 Chevrolet K1500, selecting dash/face vents produces no airflow until the A/C compressor is turned off. Other modes work, and the climate control was already replaced without curing it. Vacuum lines were checked and a damaged connection repaired with no leaks found. The floor door also fails to close fully only when dash mode and A/C are selected together. The expert explained the A/C button signals the ECM for idle-up and engages the compressor, and advised testing the mode-door actuator motors by swapping one from another location to see if the door or motor is binding.
