1995 GMC C1500 air condition
LAKE1948
  • 1995 GMC C1500
  • V8
  • 4WD
  • 185,000 MILES
My rear air does not blow cold air what do I look for
Friday, June 13th, 2008 AT 9:48 AM
DOBBER
  • 17 POSTS
Check the refrigerant pressure, if it is low you need to locate the leak, repair it and have the system evacuated and recharged, If the system is full, see if the compressor is running and cycling properly. You can jump the cycling swith on the to of the dryer and see if the compressor starts and the system blows cold.
Wednesday, September 10th, 2008 AT 6:33 PM
