1992 GMC Suburban K1500 Stuck in 4WD
ARCHIBALD
I have a 1992 GMC suburban K1500. I recently had the actuator replaced because it wouldn't go into 4 wheel when the engine was hot.Now it won't come out of 4 wheel even when I select 2H.Initially it worked but now it doesn't Help?
Archibald
Mar 20, 2006 at 9:15 PM
RAYHUT
  • 134 POSTS
Archibald how are ya. well here's the thing if i where you i would take it back to whoever done the repair and tell them it's not coming out of 4 wheel drive.(that's if you still have a warrenty).
Mar 20, 2006 at 9:37 PM
Suggested Repair
Return the Suburban to the shop that replaced the 4WD actuator and have them correct the failure to come out of 4WD, especially if the repair is still under warranty.
Conversation Summary
The owner of a 1992 GMC Suburban K1500 had the 4WD actuator replaced because it would not engage 4WD when the engine was hot. It worked at first, but the truck now stays in 4WD even when 2H is selected. The expert advises taking it back to the shop that did the repair if warranty coverage remains.
