gear shift indicator ?
MOKIEPOET
  • 6 POSTS
I took my dash apart last week and put it back together on my 93 suburban(trying to get to blower) and the gear shift indicator is wrong now. I have looked in my book, but I can't find how to adjust it. I would appreciate any advice! Thank you
Jul 19, 2007 at 3:10 PM
CLY
  • 308 POSTS
I think that has small wires that come from the bottom of the cluster and rap around the shifter bowl on the steering column(rightside). There is a clip that slides onto the bowl you can move it up or down to get the neddle were you want it....
Hope this awnsered our question....
Cly
Jul 19, 2007 at 10:16 PM
MOKIEPOET
  • 6 POSTS
I have the wire attached already. Can the little flat piece of metal on the steering column that the wire is attached to just be over?
Jul 20, 2007 at 2:23 PM
CLY
  • 308 POSTS
that is correct...move it around until the indicator is were it should be...
Cly
Jul 20, 2007 at 2:28 PM
MOKIEPOET
  • 6 POSTS
Thanks for the conformation. I didn't want to try it without someones ok- I was afaid of breaking it.
Sarah
Jul 23, 2007 at 2:29 PM
