2002 GMC C1500
FIREZOUT1
2002 GMC C1500 Four Wheel Drive Automatic
I believe the rear U-joint is going bad. How dificult is it to change the rear u joint Do I need any special tools for the job?
Jun 15, 2008 at 3:47 AM
MERLIN2021
  • 17,250 POSTS
Once you remove the driveshaft, either take it to a machine shop for pressing, or use a tourch and heat the yolk at the side of the u-joint cap. This will soften the epoxy they lock the joint with, then use a ball joint press....
Jun 15, 2008 at 3:51 AM
