1995 GMC C1500 Battery light, and voltage surge
1995 GMC C1500
150,000 MILES • V8 • 2WD • AUTOMATIC
BRETT B.
First, I recently had a lot of work done to this truck. My dealership replaced the intake gasket (due to a coolant leak). After this was done, they found the need to replace the plugs, wires, distributor, and rotor. It has been running good since.
But now, about a week later, the battery light flickers on and off in a very spiratic manner. I also noticed this morning on my commute to work that every time the battery light came on, my headlights got significantly brighter. The voltage stayed steady at about 13 volts. For the previous few days the voltage stayed at about 14 volts. But yesterday after an hour drive home, the voltage dropped to around 10. (but it was back up to 13 this morning.
Do I just need a new battery? Could the electrical parts swap have caused this problem? Alternator?
Oct 9, 2008 at 1:17 AM
RACEFAN966
  • 5,029 POSTS
Ok sounds like you have an alternator or battery problem. I would go to your local Napa or Autozone or a parts store like those that have a charging system tester. They will test you alternator and battery for free and you will know what to replace with out question. As far as the previous work possibly causing this I doubt it.
Oct 9, 2008 at 1:35 AM
BRETT B.
Thank you for the response. I will take your advice.
Oct 9, 2008 at 1:55 AM
RACEFAN966
  • 5,029 POSTS
Ok let me know what it turns up and we will go from there ok. Thanks
Oct 9, 2008 at 2:03 AM
