1995 GMC C1500 abs lights
1995 GMC C1500
85,000 MILES • V8 • 2WD • AUTOMATIC
MICHAEL MCCAIN
my pads are good but my abs light stays on
Jan 2, 2009 at 2:06 PM
BUDDYCRAIGG
  • 2,262 POSTS
when the ABS system goes through it's self-test when you first start the car.
does the light go out?
if the light comes on after you started moving then a sensor at a wheel is bad.
if it never passes the self test then you will probably want to take it to a shop to have them test it.
Jan 2, 2009 at 2:46 PM
