1995 GMC C1500 Brake Light and Service Engine Light
HAROLD HUTCHESON
  • 1995 GMC C1500
  • V8
  • 17,000 MILES
When you go foward or backwards the anti brake light comes on and it stays on until you cut the motor off and after you drive it about 5 miles the service engine light comes on and it stays on until you cut the motor off. I had it put on a machine and they said it showed that nothing was wrong.
Saturday, March 27th, 2010 AT 1:56 PM
  • 109,700 POSTS
There is a chance the scanner they used may not read codes for things other than engine components. It sounds like a bad abs sensor on one of the wheels or a bad connection. Check for connections to the ABS sensors on both the front and rear.
Let me know what you find.
Saturday, June 5th, 2010 AT 8:35 PM
