2005 GMC C1500 Check Engine light,misfir,very poor gas mile
2005 GMC C1500
110,000 MILES • V8 • 2WD • AUTOMATIC
BRETTWILSON
My trucks check engine light recently began flashing, then stayed on solid. It now goes back and forth from flashing while the engine is under a load, and solid at idle, it runs very rough at idle, during acceleration, and during cruising speeds. Where should I begin to look for the cause
Jan 15, 2009 at 1:01 PM
LITTLEREDTRUCK35
Look at your catalytic convertor. it may be plugged thus causing the bad mileage and the engine light because the air is backed up so tight the engine has to work twice as hard. Let me know!
Feb 25, 2009 at 10:32 AM
