1992 GMC C1500 electrical
1992 GMC C1500
TMC1357
Air Conditioning problem
1992 GMC C1500 V8 Four Wheel Drive Automatic 200k miles
no power to air condition compresser clutch
Mar 23, 2008 at 12:17 PM
MASTERTECHTIM
  • 4,750 POSTS
this is usually caused by low freon level. if not enough pressure it will not send power to the compressor.
Mar 23, 2008 at 12:26 PM
TMC1357
I have bought one of those recharge and repair cannisters with a guage on it and the guage tells me that the freon level is in the green range,or ok but it also states that the compressor should be running to get an accurate reading. any help?
Mar 23, 2008 at 12:32 PM
MASTERTECHTIM
  • 4,750 POSTS
jump the connector on the receiver dryer and see if the compressor turns on, this is the low pressure cut off switch
Mar 23, 2008 at 12:52 PM
TMC1357
receiver dryer connector,...where is it?
Mar 23, 2008 at 12:56 PM
MASTERTECHTIM
  • 4,750 POSTS
thats the shiny aluminum thing that the low side hose connected to when you charged the ac. it will have one switch on it with two wires, just jump the two wires together and the compressor should come on
Mar 23, 2008 at 12:57 PM
MASTERTECHTIM
  • 4,750 POSTS
its shaped like a skinny football
Mar 23, 2008 at 12:58 PM
TMC1357
thanks, i'll try that tomorrow
Mar 23, 2008 at 1:01 PM
