1986 GMC C1500 20 Fuse blows when headlight switch is on
1986 GMC C1500
103,000 MILES • V8 • 2WD • AUTOMATIC
ALEX6106
my fuse keeps blowing everytime i turn on the headlight switch at night. ive replaced it with a higher 25 fuse and even a 30 the 25 pops and the 30 just gets hot and the lights do not turn on. i also replaced the headlight swtich and that didnt solve the problem. is it a possibility that it could be the aftermarket radio i installed. Would it matter that i did a tuneup afew days ago? Im clueless i need help.
Feb 15, 2010 at 11:47 AM
DR LOOT
  • 2,311 POSTS
When you replace the headlight switch did you check the loom? I had the same problem on my truck and the wire were melted together, remove the headlight switch and checked the wires.
Feb 17, 2010 at 1:58 PM
