GM Radio - Seems to fade in and out
212,408 MILES • 3.8L • V6 • FWD • AUTOMATIC
UPMM019
  • 217 POSTS
I just bought this car used it is a one owner vehicle and has 212,000 miles on it. Seems pretty clean for the age and the owner seemed to take care and service it, so he says.
Owner said the radio does not always work, sound wise. Said he thinks there is a loose wire somewhere.
When I drove it home I ran through all of the radio options, settings. What I found is the radio works, but intermittently the sound goes away and it does not seem to be associated with bumps in the road either.
When the sound comes on it works as it should, but without notice the sound goes away.
Does not matter what mode you are in or any of the other settings. I cycled the mute switch on the steering wheel and it had no effect. When there was sound it muted and unmuted as it should.
Looking for general troubleshooting guidance.
May 10, 2016 at 12:54 AM
RYAN L
  • 273 POSTS
Sounds like a loose connector in the back of the unit. I would take the unit out and make sure all the connectors are secure. After you do that let me know if that fixes it.
May 10, 2016 at 6:23 AM
