2001 Chevy Monte Carlo It's cold
FRED HAINES
  • 2001 CHEVROLET MONTE CARLO
  • 6 CYL
  • FWD
  • 140,000 MILES
My heater/AC, cruise control and overhead display has been malfunctioning since the end of last winter. It wouldnt turn on when I first start the car, but some time during my drive they would come on. Now they have stopped coming on completely and with the weather getting bad I need my heater. Is this issue an easy fix like a relay or fuse or should I take it to a mechanic?
Monday, December 7th, 2009 AT 6:41 AM
RACEFAN966
  • 5,029 POSTS
Well I don't know if this will be easy to fix need to know what the problem is first. Weather or not to take it to a mechanic depends on how comfortable you fee with using a digital ohm meter and doing some testing with my guiding you through it. Let me know what you want to do and we will see if can't get you heat. I do need to know does the blower motor come on and work with all speeds or not?
Monday, December 7th, 2009 AT 12:17 PM
FRED HAINES
The motor doesnt come on at all. Niether does the rear defrost for the back window, my digital overhead dsiplay or my cruise control.
Monday, December 7th, 2009 AT 4:13 PM
RACEFAN966
  • 5,029 POSTS
Ok I need to know if you have climate control or not. If you do is it single or dual zone climate control?
Tuesday, December 8th, 2009 AT 10:24 AM
FRED HAINES
Yes, it's a dual climate control.
Tuesday, December 8th, 2009 AT 10:31 AM
RACEFAN966
  • 5,029 POSTS
I also need to know if you have a digital multi meter so we can do some testing? If so then what I need you to do first is see if there is power at the blower motor with the selector set on any speed.
Tuesday, December 8th, 2009 AT 10:46 AM
FRED HAINES
I do not have a digital multi meter, but can borrow one from my work on Thursday. I will check the power at the blower, where should I look next if I do or do not have power there?
Wednesday, December 9th, 2009 AT 7:43 AM
RACEFAN966
  • 5,029 POSTS
Ok there is a blower motor module connected to the blower motor. Looks like it has a 9 connector harness to it. Three look to be black, two go to the motor itselft and one goes to ground. Two orange wires one comes from the heater control should have power on speed 5 and the other should have power coming from the blower motor fuse 25amp. There is yellow speed 1, there is tan speed 2, there is lt blue speed 3, purple speed 4. Check for power to the module at the wires listed above when set on the setting listed for each wire. The voltage should increase as the speed increases. Let me know what you find ok.
Wednesday, December 9th, 2009 AT 10:05 AM
