Getting bad gas mileage
GIGISULAMANIDZE1
  • 88 POSTS
Update: no air leaks car drives good
cold start
Shrift1 (%) -2.8
longft1(%) -5.5
shrift2(%) -3.4
longft2(%) -5.5
but when worms up
Shrift1 (%) -3.8
longft1(%) -8.5
shrift2(%) -4.4
longft2(%) -8.5
Also what is RPMDSD (Desired Idle Speed) for Ford Escape 2003 3.0? Mine shows 745-780 is it normal? Aand also when I turned of IAC sensor car was running much better about 650-700 (but some times was misfiring) getting better gas mileage now.
Tuesday, February 26th, 2019 AT 11:04 AM
  • 52,797 POSTS
Got it.
Okay, you need to adjust the base idle to 500 RPM. There is a base idle screw on the throttle body and after setting the idle to 500, plug in the IAC and the idle should return to normal.
Tuesday, February 26th, 2019 AT 11:34 AM
GIGISULAMANIDZE1
  • 88 POSTS
Can you show photo where is that screw?
Tuesday, February 26th, 2019 AT 11:40 AM
  • 52,797 POSTS
Okay, I cannot see the screw in any drawing. You need to look where the accelerator cable attaches to the throttle body. It will be there.
Tuesday, February 26th, 2019 AT 12:47 PM
GIGISULAMANIDZE1
  • 88 POSTS
Update car runs smooth
shrift1 (%) _0.8
longft1(%) _ 0
shrift2(%) -_0.8
longft2(%) -0
MAX
shrift1 (%) 7.8
longft1(%) -0
shrift2(%) -5.5
longft2(%) -0
getting 26 highway
19 city
Tuesday, March 5th, 2019 AT 8:10 AM
  • 52,797 POSTS
Is the check engine light on or off?
Tuesday, March 5th, 2019 AT 10:18 AM
  • 52,797 POSTS
GIGISULAMANIDZE1
  • 88 POSTS
Check engine light was off all time. Getting better fuel mileage than last three years.
Tuesday, March 5th, 2019 AT 11:54 AM
  • 52,797 POSTS
Good deal.
Tuesday, March 5th, 2019 AT 1:16 PM
GIGISULAMANIDZE1
  • 88 POSTS
Hello, update:
shrift1 (%) 28
longft1(%) 2.3
shrift2(%) 32
longft2(%) 2.3
car runs bad. :/ Only thing that I changed today is vacuum break booster (bought from junk yard) it's can be bad vacuum break booster? Car was running good when I changed vacuum break booster than car was running bad and rpm are high.
Sunday, March 17th, 2019 AT 11:16 AM
  • 52,797 POSTS
Junk yard parts are never a good idea.
Yes, it sounds like it is bad. I would get a rebuilt one.
Sunday, March 17th, 2019 AT 3:39 PM
