no power to coil
BIGHEAD1121
i have a 93 geo storm i am getting only getting power to 1 prong on the plug to the coil.i put 2 new coils on it thinking the 1st new one was badbut nothing seems to work all fuses are good and i am lost this is my mothers car she said she was going down the road and it just died can someone please help me!! i just want this thing out of my yard i am redy to junk it thanks
Feb 15, 2006 at 10:33 PM
BIGHEAD1121
thanks for the info. it doesnt show if power should come out of more than 1 prong on the plug. also if my timing belt broke will i get power thru the coil thanks again guys
Feb 16, 2006 at 5:45 AM
PEPPERMRJ
  • 1,158 POSTS
[quote:1e84e8a7c7="bighead1121"]thanks for the info. it doesnt show if power should come out of more than 1 prong on the plug. also if my timing belt broke will i get power thru the coil thanks again guys[/quote:1e84e8a7c7]
First what engine and how many miles?
What is the problem that caused you to replace the coil. I assume it will not start. If this is the case then do you have spark?
I do believe that only 1 coil terminal should get power.
If the timing belt broke the rotor inside the distirbutor will not turn as the engine is being cranked over.
Feb 16, 2006 at 7:24 AM
