1992 Geo Storm Electrical Failure Between Ignition and Igni
1992 GEO STORM
144,000 MILES • 4 CYL • FWD • AUTOMATIC
SCOTTMD06
My car has been having an electrical problem with starting up on occasion. Some days there is no problem. We've checked the battery, replaced the distributor cap and rotor, replaced the ignition coil and no luck. When it does start up I can drive it but it will sometimes just die and not want to start back up. We've pinpointed that when it's refusing to start, we can't get spark to the ignition coil. Are there any mechanics out there who have experience with these symptoms that may have some suggestions?? Thanks!
Jun 23, 2009 at 12:42 PM
Check and test the ignition components and the ignition switch
Jun 23, 2009 at 12:45 PM
SCOTTMD06
okay will do. is there anything in particular i'm looking for?
Jun 23, 2009 at 12:49 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Jun 23, 2009 at 2:16 PM
SCOTTMD06
thanks for all your help.
Jun 23, 2009 at 2:20 PM
VBOSS5764
  • 23 POSTS
[quote:df4f8ecd9c="scottmd06"]Electrical problem
1992 Geo Storm 4 cyl Front Wheel Drive Automatic 144000 miles
My car has been having an electrical problem with starting up on occasion. Some days there is no problem. We've checked the battery, replaced the distributor cap and rotor, replaced the ignition coil and no luck. When it does start up I can drive it but it will sometimes just die and not want to start back up. We've pinpointed that when it's refusing to start, we can't get spark to the ignition coil. Are there any mechanics out there who have experience with these symptoms that may have some suggestions?? Thanks![/quote:df4f8ecd9c]
Ignition module is a very common failure, its a common GM module, under the dist cap, takes a 5.5 mm, pull it and have it checked.
Jun 30, 2009 at 12:34 PM
