You will have to get the fuel pressure checked with a mechanical gauge, this can (generally) only be done by Toyota or someone with the special tool set required to measure it.
I would go ahead and change the fuel filter, if you can, if problem persists, you will need to start as I mentioned above, fuel pressure first, then ignition if pressure is OK.
SPONSORED LINKS
Wednesday, September 26th, 2018 AT 11:54 AM
(Merged)
