1993 Geo Prizm
LLAMB20
  • 1993 GEO PRIZM
Warranty problem
1993 Geo Prizm 4 cyl Front Wheel Drive Manual
my 93 geo prizm cut off(battery warning light came on)jumped start the car, got it running. Can, t put the car in drive. Stick shift won, t go in reverse, neutral, or drive.
Saturday, September 13th, 2008 AT 5:35 PM
MMPRINCE4000
  • 8,548 POSTS
The battery light is the battery or alternator.
The shifting problem may be the clutch MC or slave, or linkage (or collapsed motor mount).
Have someone use the shifter while you observe is there is any movement on the cables on the trans. Could be a bracket is loose/broke, or cable is broke.
Monday, September 15th, 2008 AT 7:17 AM
