the check engine light comes on and then the motor looses all power and the car has to then be turned off and wait a few min to start and try again i have check the code and it is 52 with no other codes have done it 3 times now. the code says the cal-pak missing. i have looked for 2 days now on any info to help this problem but have found none any help would be great thank you
Jul 1, 2010 at 10:30 AM
