1997 Geo Metro No Power After Jump
97GEOGUY
I have a 97 geo with 222222miles...its the four cylindar metro.
The alternator belt broke a while back and we replaced it. Battery was still going dead. had the wife go and have it tested.. they told her it was only putting out .9 amps. Well the battery died and she decided to jump it. She said she did not cross the cables.... but now there is absolutly nothing. Even with booster cables on and clearly good connection between batteries I dont even get the dome light to come on.
Any ideas?
Jan 29, 2007 at 12:31 AM
BRUCE HUNT
  • 3,754 POSTS
Under the hood on most cars is a fuse box besides the one inside the car. They have a master fuse that could be blown.
With the car running again. Hook a voltohm meter to the positive and negative on the battery. Read the voltage. Under 14 volts and the charging system is not working properly to coincide with the test that was run. Therefore, I believe that you are looking to replace the alternator.
Jan 29, 2007 at 8:08 AM
Suggested Repair
Check the under-hood fuse box master fuse, which may be blown. Once the engine runs, measure battery voltage; if it is under 14 volts, the charging system is faulty and the alternator should be replaced.
Conversation Summary
A 1997 Geo Metro with high mileage had a broken alternator belt replaced, but the battery kept dying. A test showed only 0.9 amps of output. After a jump start, the car had no electrical power at all, including no dome light even with booster cables connected. The expert advised checking the under-hood master fuse and testing charging voltage; under 14 volts indicates a bad charging system and a need to replace the alternator.
