1995 Geo Metro Distributor Oil Leak Fix
BARB3189
I have been told that I have oil leaking from my 1995 GEO Metro -3cyl- Standard Trans. Distributor and that it should not be hard to fix. How do I go about fixing it?
Sep 7, 2007 at 7:55 AM
MERLIN2021
  • 17,250 POSTS
Is your question how to stop an oil leak at the distributor? if yes you will need to remove the distributor, install a new "o" ring and re install the distributor! Don't forget to mark the distributor!
Sep 7, 2007 at 11:25 AM
Suggested Repair
Remove the distributor, install a new O-ring, and reinstall it. Mark the distributor position before removal so it can be reinstalled correctly.
Conversation Summary
The owner of a 1995 Geo Metro with a 3-cylinder engine and standard transmission was told oil is leaking from the distributor and asked how to fix it. The expert said to remove the distributor, install a new O-ring, and reinstall it, marking the distributor first.
