1997 Geo Metro has no power and will not idle
KEVIN8378
  • 1997 ALL OTHER MAKES ALL OTHER MODELS
1997 Geo Metro 1.0 140,000 miles. This car has no power. It will not idle unless I hold the peddle down a little. I can't get it to go over 65mph. If it does idle as soon as I turn on the lights, heater, or wipers ect, anything that will draw power it dies. There is also a pinging when I accelerate or go up an incline. I also have to keep it in each gear longer than I normally would before I shift. I have replaced the upper o2 sensor and the air temperature sensor. Also the spark plugs and cleaned the EGR valve. I replaced the fuel filter 20,000 miles ago. I have also noticed that the air filter is soaked with gas. My gas mileage has dropped dramatically also. I have checked the compression in the cylinders and found they are 150lbs, 125lbs, and 60lbs.
Friday, November 10th, 2006 AT 1:39 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the catyletic converter is plugged. Try loosening the exhaust flange at the exhaust manifold. It will be a little loud, but drive it and see.
Thursday, November 30th, 2006 AT 11:26 AM
GEO_JAK
Just one tooth off and you get those symptoms.
But my bet too is on a clogged cat conv
or even a damaged (crushed) exhaust pipe. Lack of clearance for the intake of air to go out
baught a car like that for $89 once. The owner had drove over a cement parking block. Lol
JC
Friday, August 14th, 2009 AT 12:25 AM
