Ok, I just replaced the fuel pressure regulator hoping that was the problem. The car fired right up and idled perfectly. I let it warm up and tried revving the engine but still had the same problem. If I slighlty apply pressure to the gas pedal it revs up fine, but if I apply normal pressure up to punching it between idle and 2500 rpm, it bogs out until I release the gas pedal. Anywhere above 2500 rpm seems to run fine. I shut the car off, pulled the plugs and disconnected the battery. The plugs were ok and it's still getting really good spark. I tried starting it again and it wouldn't even start, just keeps turning over with a almost here and there. A friend suggested an air flow sensor? What do you guys think? Thanks!
Monday, March 5th, 2007 AT 11:24 AM
