1997 Geo Metro wont stay running
1997 GEO METRO
132,000 MILES • 4 CYL • FWD • AUTOMATIC
EAZY0167
Replaced fuel pump,filter it ran fine for few days thenn started stalling out while on hwy then would start up. A day later wouldnt start sprayed starting fluid and it started and ran for little while. Now wont start without starting fluid and dies quickly after but not right away.
Jul 14, 2008 at 7:19 AM
DJCARSON
  • 10 POSTS
I had the same problem and it was the fuel injector wire harness. there was actually a recall on that part, but you cant find it anymore. i wiggled mine around until i got the correct ohm reading listed in the haynes manual. sounds like it could be the same problem. good luck
Jun 18, 2010 at 4:12 PM
