1997 Geo Metro won't fire
SUZYCUTIE
Electrical problem
1997 Geo Metro 4 cyl
Car died while driving. Found wires worn through in harness by belts. Spliced them back together. Still no spark. Took the coil in to be tested. It's operating within proper range. Still not firing. Could it be the ignition module?
Sue Wesely
Sep 12, 2010 at 9:54 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sep 12, 2010 at 12:40 PM
