My gear is stuck in reverse and I can't shift out clutch pedal goes all the way to floor and it won't release the gear.
May 15, 2020 at 9:16 AM
✓Experienced Mechanic
Because of the model year, I can't seem to find pics. So, lets try this without. When you depress the clutch, does it feel normal? Will it shift from reverse with the engine off?
Also, have you checked the linkage at the transmission and shifter?
May 15, 2020 at 2:12 PM
