Fuse #13 in engine compartment keeps blowing
AGEL
  • 40 POSTS
Ok las thing I did is try star the car without the ecm conected and the fuse blew up
Monday, March 12th, 2018 AT 5:34 PM
AGEL
  • 40 POSTS
I dont know what alse to check
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
It sounds like the ECM is shorted out and you need a used or new one. I would send it out to have it rebuilt.
Tuesday, March 13th, 2018 AT 10:08 AM
AGEL
  • 40 POSTS
Do you a place to rebuilt it
Tuesday, March 13th, 2018 AT 10:29 AM
KEN L
  • 48,363 POSTS
Check ebay most of our guys use services from there. Also you might want to open it up to check for water damage in which case it may be junk
Tuesday, March 13th, 2018 AT 11:05 AM
AGEL
  • 40 POSTS
Ok thanks
Tuesday, March 13th, 2018 AT 11:07 AM
AGEL
  • 40 POSTS
One more thing why did the fuse blew up without the computer been conected
Tuesday, March 13th, 2018 AT 11:08 AM
CARADIODOC
  • 33,916 POSTS
Did you try my suggestion of replacing the fuse with a light bulb?
Tuesday, March 13th, 2018 AT 5:59 PM
AGEL
  • 40 POSTS
Could you show me where the ignition failture is located
Wednesday, March 14th, 2018 AT 1:42 PM
CARADIODOC
  • 33,916 POSTS
You've been replacing a fuse, so you know where it is. Put a light bulb in there instead of a fuse. A typical brake light bulb will limit current to around one amp so the wiring will be protected. When the circuit is turned on and the short is present, the bulb will be full, normal brightness. Hang it where you can watch it while you unplug stuff and move wiring harnesses around. When you do anything that removes the short, the bulb will turn off or be dim. In some cases, depending on what else is in that circuit, the bulb may only dim a little when the short is removed so you have to watch closely while you move stuff.
Wednesday, March 14th, 2018 AT 3:43 PM
