Engine acting like it is running out of fuel?
18,300 MILES • 1.6L • AUTOMATIC
JENNIFER CALLAHAN
It will lose power start sounding like it's trying to shut off but doesn't .it will drive good for a minute but does it again.
Apr 17, 2021 at 9:06 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
The first thing I would suggest is to perform a fuel pressure test to rule out a weak or failing fuel pump that is not supplying adequate fuel pressure. If you don't have access to a fuel pressure test most auto parts stores have a tool loaner program and can rent you one. Here is a tutorial showing what is involved on how to perform a fuel pressure test:
The fuel pressure specification for your car is with engine idling to be 28-36 PSI. Get back to us after performing this test with the results and we'll go from there. Hope this helps and thanks for using 2CarPros.
Apr 17, 2021 at 9:40 PM
