Crank not start after the airbags were deployed, fuel shut off/inertia switch?
30,000 MILES • 2.3L • 4 CYL • TURBO • 2WD • AUTOMATIC
JOSTANGECO19
Hello, sorry to bother you but i have a question and problem. i own the car listed above ecoboost. Is there anyway i can override the computer, reset my car, and take off the fuel shut off? There's no damage to the motor or anything but the airbags went off and it won't turn on but it will crank. Thank you
Nov 19, 2022 at 3:28 PM
STEVE W.
  • 15,399 POSTS
If it has a key, turn the key on, then off, repeat that twice and try to start it. If it has the push button start, hold the brake down, push the button to run, let off the brake, go back to off, repeat that twice and try to start it the third time. If it still won't start there is another problem, probably has to do with the airbags being deployed so they need to be repaired before it can be driven.
Nov 20, 2022 at 1:50 AM
