Not getting fuel
TRAVLIN
  • FORD MUSTANG
My 1988 ford mustang is not getting fuel I have narowed it down to a fuel pump shutoff switch that I cant locate can you give me some advise ps the pump works properly when I hook it to the battery but my light tester say's i'm not getting any power to the pump with the key turning any other advise will be helpful also
Sunday, January 28th, 2007 AT 8:06 PM
SERVICE WRITER
  • 9,123 POSTS
Do you have anti-theft? If so try another key. The reset is usaully on the left rear trunk area behind a panel.
Sunday, January 28th, 2007 AT 8:11 PM
TAURUSWHEEL
  • 718 POSTS
I believe there is a fuel pump relay within the integrated control module(at least that's what is called on my 87 Taurus). It's the black box on top of the radiator shroud. Newer models call it the ccrm, constant control relay module. On the earlier models such as mine I don't believe the individual relays are replaceable, however you can drill out the rivets on the box to expose the inner workings, maybe you can take it further from there.
Sunday, January 28th, 2007 AT 11:24 PM
