1966 Ford Mustang Fuel Gauge Reads Half
ICYFLAME68
1966 Ford Mustang, 70,500 miles. Originally, this car was an inline 6 and changed over to the 302 V8. I've been having a problem at the gas station: The pump shuts off at 9 gallons, give a little, and the fuel gauge never shows more than a little over half full. I know that these cars have a capacity of at least 13 gallons, so what gives? I'm fairly sure the prior owner did not tamper with the tank.
May 21, 2007 at 6:34 AM
RUDPRO
  • 224 POSTS
The float in the gas tank for the fuel gauge is probably bad. If the gauge is not accurate you may have more fuel in the tank than you think and that's why it's only taking 9 gallons. Take the float/sending unit out of the gas tank and with the key turned on, move the float up and down and have someone watch the gauge to see if it's accurate.
May 21, 2007 at 8:21 AM
Suggested Repair
The fuel-gauge float or sending unit is likely inaccurate, so the tank may already hold more fuel than the gauge shows. Remove the sending unit, turn the key on, and move the float up and down while someone watches the gauge to check whether it responds accurately.
Conversation Summary
A 1966 Ford Mustang converted from an inline-six to a 302 V8 stops accepting fuel at about 9 gallons, and the gauge never reads much above half despite a tank capacity of at least 13 gallons. The expert says a bad tank float or sending unit may make the gauge read low, causing the pump to shut off early. They recommend testing the unit by moving the float with the key on and watching the gauge.
