Fuel pump
250,000 MILES • 0.6L • 4 CYL • 2WD • MANUAL
SHAWNARICKETTS
Fuel pump wont come on unless i jump it from the dlc 1, there isnt anyway i can just run a switch straight from there to the inside of my truck until i can figure out where the problem is!! Can i start the truck with that jumper wire running from the fp to b+ or is that just for testing or what!! I cant figure out wrf ithe problem is! Somebody saud something about there being somekinda switch or triped breaker on the passengers side i dunno!
May 19, 2019 at 11:25 AM
  • 55,740 POSTS
The fuel pump wont turn on if the ECU doesn't see i signal from the ignition system. do you have spark? Here is a guide to help us see:
May 23, 2019 at 5:05 AM
